I’ve been thinking about how network audio behaves across different parts of the chain, and I wanted to share a conceptual model that has helped me understand the roles of buffers, switches, and timing.
This isn’t meant to be definitive—just a framework that might be useful for discussion.
Here’s the full model.
Static vs Dynamic Domains in Network Audio:
Why Buffers, Switches, and Timing Still Matter
This note outlines a conceptual way to think about how digital audio behaves as it moves across a network. Rather than focusing on implementation‑specific details, the goal is to provide a structural model that helps explain why certain parts of the chain influence timing, stability, and ultimately sound quality.
1. Static Domain and Dynamic Domain
Digital audio exists in two fundamentally different states, each with its own characteristics.
Static Domain
Data resides in memory, cache, or buffers
No time axis is involved
Jitter does not exist here
Only bit‑level correctness matters
Dynamic Domain
Data is being clocked, transferred, or converted
Timing uncertainty (jitter) appears as an energy‑related phenomenon
Power stability and load behavior influence timing precision
Understanding this distinction helps clarify why some components affect sound quality while others do not.
2. Nodes as Reset Points
Every network node—servers, switches, endpoints—acts as a temporary static domain.
Once data enters a buffer:
Any timing uncertainty accumulated earlier is eliminated
Jitter does not propagate across nodes
Timing is regenerated at each dynamic segment
This explains why upstream behavior still matters:
it shapes the conditions under which the next dynamic process operates.
3. The Transport Chain
TCP/IP → RAAT → Diretta → L2 Switch → DAC
(1) TCP/IP — Static Integrity
Ensures:
Bit‑perfect correctness
Packet ordering
Retransmission
Buffering
This layer preserves the purity of the static data.
(2) RAAT — Structured Static Stream
RAAT organizes static data into a stable audio stream:
Still largely static‑domain behavior
Buffering at each node resets timing
Prepares data for time‑domain unfolding
(3) Diretta — Reducing Dynamic Variability
Diretta operates in the dynamic domain and aims to reduce:
Load fluctuation
Power‑related disturbances
Transfer timing variation
It minimizes jitter generated during motion.
(4) L2 Switch — Final Dynamic Relay
The switch is the last place where packets are buffered, queued, and clocked before reaching the endpoint.
Its internal conditions—power stability, load uniformity, port behavior—shape the final timing profile delivered to the DAC.
Thus, the switch becomes the final dynamic‑domain relay.
(5) DAC — Converting Timing into Sound
The DAC converts dynamic timing into analog voltage.
Therefore:
Static‑domain purity (TCP/IP → RAAT)
Dynamic‑domain stability (Diretta → L2)
both influence the final audible result.
4. Empirical Observations
Across measurements and listening tests, several tendencies appear consistently:
Load stability improves downstream timing
Uniform network behavior reduces disturbances
Static load conditions help dynamic processes operate more cleanly
Separating noisy power domains reduces coupling
Diretta reduces timing variability at the endpoint
Cleaner upstream nodes allow the switch to operate more predictably
These observations align with the structural model above.
5. Integrated Perspective
The conceptual model and empirical tendencies reinforce each other:
Static‑domain purity sets the stage for dynamic precision
Dynamic jitter is shaped by power and load behavior
The switch forms the final timing profile
The DAC converts that timing into sound
Together, they form a coherent way to understand network‑based audio behavior.
Closing
This is simply one possible framework.
I expect that different interpretations and perspectives will reveal aspects I have not considered.
I’ll leave the discussion to everyone here.
