After a power outage I had to restart my Rock. Now the tidal page says “failed to load albums” in the album section. I also get a message that says “error loading page. Please check your network connections”. My network connection is fine, though. The tidal playlists are also empty. I am also getting a message that Roon metadata is halted for a new update but I have the latest version.
Did you restart your network before restarting the ROCK ?
I power down every day and often see that, I put it down to Tidal not being connected before Roon needs to connect
Try starting the network, wait a few mins until everything’s stable then reboot the Rock
May work
I thought the issues were resolved last night but I woke up this morning and the problems reappeared.
Reboot everything you can possibly reboot.
Listened to the above experts. Problem solved.
No expert just time worn experience
