I have a lot of stuttering recently with Ropieee connected via usb to a Moon Dac. All other zones works perfectly fine. (Macbooks, Chromecasts etc.) Sometimes it goes away after a reboot but return momentarily. This occurs with both local and Tidal tracks.
Raspberry Pi 3, cable connected. Rock on Intel NUC.
Stuttering is often network related, though with a Pi, USB and network share the same internal bus - so if you’re playing hires, it may be saturating. An audio ‘hat’ can alleviate this by replacing the Pi’s onboard USB port.
If it’s the pi 3+ the ethernet causes all sorts of issues with usb audio and hires. Limiting it to 192 sorted it on my mine. Pi and USB are not the best bed pals.
