ATT Fiber Optic -Ethernet
ONT via Ethernet > Buffalo Switch >Telegartner M12 Gold switch > Taiko Audio Extreme via USB > Vivaldi One
None of my remote devices (iphone, ipad, macmini) can connect with Roon Core which is the Taiko Audio Extreme. Intermittently, I’ve had this issue but have ultimately been able to reconnect by reinstalling the Roon Remote app or entering the ip address of the Extreme. This time nothing I’ve tried works. Thanks for the help!
I didn’t do the obvious and reboot the Extreme. When I did all devices were able to connect. Thanks for your help wizardofoz! BTW, the Buffalo is “just” a switch…
I would highly recommend you have a router after the ONT ethernet connection, and before any switch this is typical connectivity setup and could be exposing your system to outside threats otherwise.
Unless its a very odd ONT with a router and AP then it is the router
Thanks for the info! I go from the ONT to an Edge Router X SFP. This allows me to separate the audio from the home network. When I did that it revealed a more vivid musical presentation!
