Hello
i want to buy a surface pro 7 using as my home computer.
Is it possible to use also as my remote for roon (my core is Innuos and my streamer is Gold Note DS 10+).
Thank you.
Volker
The Surface is a Windows 10 PC, so just download Roon for Windows from here:
Roon installed on your Surface will act a Roon remote for the Core on your Innuos - just choose that Core when Roon first starts up on the Surface Pro.
Danke für die schnelle Antwort!!
Thank you for your prompt reply!!
