SVS Prime Wireless Pro Soundbase not recognized by Roon (ref#PWMS3F)
· My DAC, streamer, or speaker doesn't appear as a Zone in Roon
· Connected directly to my RoonServer machine
· No, it does not show up there
Since you are using a network connection to the device, please ensure that your RoonServer is on the same subnet as the device
· My devices are on a single subnet but is not visible to Roon
· I have a *mesh network* with devices connected to multiples points
Your local network might need some re-arranging to support Roon.
· None of the suggestions have helped me. I'd like to submit a support request.
· SVS Prime Wireless Pro SoundBase (This device was working on the same network mesh router in the past)
The SVS Prime Wireless Pro Soundbase is not recognized by roon (in was in the past)
Connected via Mesh Network Router (TP-Link Deco V 3.8.69)
A bit more information – The SVS SoundBase was recognized and working fine. I did move the unit to another location but it looks like the network is recognizing it. I restarted Roon and unplugged and plugged the SoundBase back in. I waited to purchase the SoundBase until I knew it was Roon tested… Thank you for any suggestions
Fixed – After I restarted my MBPro which is running Roon… Sorry, I should have thought about this…
