ROON ROCK running on NUC8I7 connected by ethernet to my router Asus RT-AC86U
Audio system setup
The problem relates to grouping these two systems
- NUC --> Ethernet --> AC86U --> Ethernet --> Pi4 with Hifiberry Digi+ Pro and HifiberryOS --> Coax --> DAC in Hegel H160 --> B&W804D2
- NUC --> Ethernet --> AC86U --> Wifi --> Pi4 with Hifiberry DAC2 HD and HifiberryOS or RopieeeXL --> RCA --> B&O A9
When grouping these two zones (using RAAT or Airplay in Pi4) the music is way out of sync. The maximum setting for delay when grouping zones in Roon seems to be 1000 (ms I guess), but this is not enough to get the music in sync.
When grouping using Airplay in Pi4 (1) and the built in Airplay in the A9 (2) there is no delay, even though it’s still over wifi, which makes me believe that the problem relates to the wifi on the Pi4.
I much prefer to use RAAT over Airplay, as the sound quality is much better - especially on my main system, so any suggestions will be most welcome!
If not I will make a feature request making it possible to adjust the grouping delay more than 1000.
