System Minimums and Install Issue -- Macbook Air
Hi there. Am trying to install a Roon trial on a 2010 Macbook Air running a Intel Core2Duo, 4GB RAM, 256 GB SSD with 13 GB free space. I go to open the Roon download and it does not install. Is my system too far below specs? If so, is there a way to transfer the trial to another computer? Thanks.
Bob F.
Hi Bob,
There is a post What are the minimum hardware requirements? in the Support FAQ category that may help.
As for moving the trial to a different computer, just go ahead and install it, when it runs it will prompt to move over the licence to the device.
Hi Carl,
Thanks much for the prompt response-- will give it a try on the other machine.
