Router: Xfinity xFi Gateway
2020 Mac Air running Ventura 13.1 operating via wifi
Roon Server Software Version 2.0 (build 1193)
Roon Labs Software Version 1.0 (build 14)
Naim Uniti Atom
57,397 Tracks
I have 57,397 tracks downloaded in my Nucleus as shown in this screenshot from the summary page.
Yet when I look at the Nucleus Internal storage under settings it only shows 49,809 and fails to update that number when I add new tracks or force a rescan.
It is virtually stuck at this number. Any thoughts on what this means and how to fix it?
And here is an interesting and timely update. The count on my tracks has been constant for well over a year. I just added 4 tracks from files and one of them actually registered a bump on the count. Clearly something is wrong with the file scanning and I suppose that if the files show up and I can play them I should just continue to look the other way as I have for over a year. The only reason I posted this is the thought that this may indicate a bigger issue. When you have 50K+ tracks you tend to get conservative about data loss
Oh man, I thought that was a great idea and one that might reveal something but with streaming services disabled the number stays the same. I am starting to think I should just leave well enough alone
OK, if I heard you correctly the “49,809” tracks showing should be what is on my Nucleus, right? But that number is changing (except once) when I add tracks to the nucleus. Am I reading you right here?
Appreciate that, but I have been down all those paths and have forced endless re-scans. No worries. I am going to close this ticket and simply live with it. In the end as long as I can play the music I am good to go.
