When I play using my Modi DAC into my Amp it plays perfectly. However, when I want to play through my system output which is set to my Bose Companion 5 speakers, it skips through all the songs. So if I play an album it speeds through each song one after another without playing any of them.
This is also the case when I use the speakers as their own zone, apart from my system output.
Hi @Jacob_Gordin ---- Thank you for the report. In order to better evaluate what may be causing this behavior to occur, may I kindly ask you to please provide the following information:
Hi @Jacob_Gordin ---- Thank you for the follow up. I’d like to take a look at your RAATServe logs and will be contacting your via PM momentarily with instructions on how to send them over to us.
