T8 not appearing as a Roon audio device after rebooting (ref#0YCJTF)
· I posted in this thread because my new T8 is not showing up as a Roon audio device. I've rebooted my Mac, my network switch and the T8 and the T8 doesn't show up as a device in Roon. I figured since this thread was a T8 thread, a lot of the posters would be able to share what they had done to access Roon Ready on the T8.
· MikroTik switch in my office->fiber to stereo room->etherRegen switch->RJ45 to Eversolo T8->USB to Esoteric N-05xd
Hello @vgrubb
macOS Sequoia (version 15 and higher), has tighter (and more obfuscated) network security settings than preceding MacOS versions.
Can you please navigate to macOS System Settings > Privacy & Security > Local Network, and make sure Roon and Roon Server are allowed.
If it is already enabled, toggle it off and on again. Then reboot your Mac, and see if the same issue persists.
That worked. It had been working just fine with Roon to the streamer in my DAC and with Audirvana to the T8, both from the Mac.
