The title says it all; when i manually change song or adjust the volume with the app i, most of the time, hear a tick through the speakers. The higher the volume the louder the tick.
I use ROCK on NUC i7, controlled through my iPhone 11pro and Samsung pad. Playback through USB to Topper D30PRO DAC → Hypex class D NC250MP mono blocks.
Any ideas? Restarting/updating/cable switching tried within means.
Yes, I’ve had a similar issue since day one with IPad Air > Nucleus+ > SR Ethernet switch > Gold Note IS-1000 integrated amp Roon endpoint via Ethernet cables. Pop or click between every song coming from Tidal & Qobuz but not from external library. Tried numerous recommendations including Resync Delay with no luck.
Interesting, I only get clicks when changing volume and pausing, fast forwarding or jumping songs, but not between songs in playlists or albums, unless there’s a sample rate change.
No difference between local or streamed content - after all, it’s very likely a RAAT protocol related thing.
Never an issue with my system no clicks whatsoever. Sound more like a DAC related issue than a Roon one I have 9 setups and don’t get clicks on any of them at all.
To me this sounds like Roon controls the Volume on the interface module (XMOS XU208) while the knob is likely using the volume control in the DAC-chip (CS43198) itself.
I’m not a fan of digital volume control. Work towards a nice preamp and it will solve the volume clicks. That’s hideously inconvenient and expensive answer but that’s my recommendation.
As far as pops / clicks when when changing songs this can be solved by replacing the DAC. Some DACs handle these rate changes / dramatic bit stream differences without issue. Some just sort of glitch and that’s what you’re hearing. For example, my DAC has physical muting relays on the outputs when a rate change occurs and the relays don’t disengage until the DAC has clocked to the new clock. This prevents any noise or static during a rate change. You might also want to try another endpoint. Some endpoints are a little more graceful in this regard as well.
One question though… is this the same behavior at all bit-depths and resolutions? Some DACs have a “happy place” where you may notice this less at a specific bit-depth / resolution (say 24/192 or 32/192). If that’s the case you could let Roon upsample to this resolution which would reduce the issue.
Just did some testing; when really paying attention i find when the volume slider is operated slowly it’s no issue. When scrolling or changing volume is done abruptly it happens the most. But not always, I’ve checked the bitdepth via the signalpath during my testing and could only see a difference in automatic volume adjusting by Roon. All other values were the same, all streamed via Qobuz i have to add.
