Tidal connectivity problem
Now 24 hours without Tidal function with Roon and various fixes tried. Roon operating fine, Tidal apps work fine but not in Roon.
I’m signed in but getting message in pink box;
‘Error loading page, Please check your network connection.’
Tried rebooting Core (multiple times) and router, changing Tidal password and read all I could find in the forum but nothing doing the trick. Stuck! Help…
System;
Core on Nimitra > Mytek Brooklyn DAC+
Location;
Scotland
@support
You could try the following:
It may or may not help!
I just used that fix last night for the same problem and it solved it! Tidal back up and running on Roon! JCR
Tidal back on Roon :+1:
