Tidal does not work inside Room anymore
Mac Mini, Mac OS11.2, Roon 1.7 (build 710)
Ethernet
Since yesterday Tidal does not work inside Roon anymore; login into Tidal via Safari works without any problem; login via Roon shows the following feedback from the browser "You’ve successfully connected your TIDAL account ", but in Room Tidal is not connected.
Roon is playing the music located on the MacMini as always.
Sorry for the trouble here, @Volker_Clausen!
Since experiencing this issue have you tried rebooting the Core machine?
What browser are you using? If you use a different browser, or try signing in from a different remote, is there any change?
Thank you for your quick reply. In-between I did find the reason: it was a problem with the internet-connection of my server. Now everything is running fine again.
