Tidal dropouts with Roon Radio, MQA dropouts
  • Core Machine (Operating system/System info/Roon build number)
  • Lenova SS drive, 8gb ram, all wired internet, running windows 10. Version 1.7 (build 521 stable)
  • Network Details (Including networking gear model/manufacturer and if on WiFi/Ethernet)
  • MTA modem/router. Ethernet.
  • Audio Devices (Specify what device you’re using and its connection type - USB/HDMI/etc.)
  • Raspberry PI 2.5+ , running ropiee into ps digital 2 dac.
  • Tidal dropping out frequently. While playing roon radio will only limit to library and not be able to use tidal. MQA dropouts as well.
Hi @Marc,
Does the same behavior occur when you try playing to “System Output”?
Have you tried rebooting your Core/Networking gear yet?
It looks as though the problem was solved. Noris mentioned that there was a glitch that was fixed. So far so good.
