Core Machine is ROCK on an Intel NUC, Version 1.8 (build 903) stable
Core and end points are mostly hardwired, no managed switches in the loop.
The only network oddity is I run a Pi Hole DNS ad blocker on the network. I have checked the logs here but can’t see any Roon/tidal traffic being blocked.
Multiple network connected devices, including:
Airplay Surround reciever
MicroRendu
Google home devices
around 33k tracks
I have been using Tidal / Roon for a number of years with no major issues. For the last couple of weeks I have been having problems with my library.
I often look through Tidal and heart albums from Tidal, to listen to them at a later date through Roon, recently it looks like these items aren’t syncronising and adding into Roon. I have had to get home and then add the album through the Roon interface.
An example of my Tidal and Roon albums, sorted by date with no filtering:
Hi, @Matthew_Clegg, thank you for your report. Do you mind if we pull a diagnostics report from your Core? The last screenshot of yours indicates a networking issue. We need to take a look at Roon logs to get a better understanding of what’s happening on your Roon Core.
Of course Ivan, how do we proceed?
The last issue is very intermittent, and I suspect it is due to rate limiting on DNS requests on my network. I have rebooted the server and it seems to have cleared, though the library is still noy syncing.
Thanks, @Matthew_Clegg, I will send a request via our support system and I hope that your Core will be able to send the data to us. After this, we will analyse it and @david.p should come up with the next steps.
02/23 01:28:34 Trace: [tidal/storage] sync completed unsuccessfully in 20862ms: Result[Status=NetworkError]"
This means that your TIDAL account cannot finish the syncing procedure. After looking around this line in the same log, we noticed a lot of these errors which are intermittent:
02/23 01:28:38 Warn: [easyhttp] [1112] Get https://metadata.roonlabs.net/1/albums/166:0:304838/tracks?c=tidal-gb web exception without response: Name or service not known (metadata.roonlabs.net:443) Name or service not known (metadata.roonlabs.net:443)
It points to a DNS-related issue. As the next step, we suggest temporarily turning off the Pi Hole DNS adblocker. Let’s see if that helps.
Ok, so I have set Rock to bypass the Pihole by using a static IP (Pi hole also serves DHCP) and setting the DNS up be google (8.8.8.8).
That has fixed the problem, and does point to a problem with the way pihole is serving DNS.
I would love to try and understand why, since it looks to all intents from the logs that PiHole is responding to A record requests correctly.
Have you come across anything similar, I will trawl the forum. Any thoughts? Could it be anything to do with the IPv6 (AAAA) requests that are failing with no IPV6 DNS results returned?
I am also interested if anything has changed at your end, as pihole and Roon have coexisted for the last year.
I could not get Qobuz or Tidal to work with Pihole when I tried
it out recently. Not being the greatest expert in these things I just abandoned it and removed pihole.
