Tidal problem: first wont connect than does not load albums [Issue went away on its own]
For a few weeks now Tidal would not connect when I start up Roon on my MacBook Pro. First it fails to connect for a few minutes. When it finally does, albums do not load.
I realize that this problem has already been described elsewhere but my technical knowledge is limited so I fail to understand the solution.
Thanks in advance for taking a look!
Bildschirmfoto 2020-12-18 um 23.37.48
Now it works fine again. I am confused.
I’m glad things are currently working for you, @Snow! Have things continued to work since your last update?
Yes thanks!
