Hello…,
Recently, the red line on the timeline is no longer in sync with the music.
My setup consists of a sonicTranspot 7i from Small Green Computer with the Roon Core and the HQPlayer Embedded on it. From there it goes to the La Rosita Gamma with on board the Micro Rendu and the DAC of La Rosita. For PCM I use the L-filter of the HQPlayerd configuration and it gives a delay of about 5 seconds. This means that the red line is on its way for 5 seconds before music is heard. But now it is suddenly different. It takes at least 10 seconds before the music starts and after this the red line starts after 5 seconds. This only happens when I select the track. When the next song starts there isn’t that long time gap but the red line is still 5 seconds behind.
This event is not due to a change in setting.
What have I tried:
I have rebooted both the Micro Rendu and the sT with HQPlrd and had the sT update the HQPlayerd as well. None of that helped.
Has anyone experienced this before and perhaps found a solution for this?
Greetings, Bert Dijkstra.
