I am running into, at least I think, into the same issue as a few others that roon has added tracks, but gets stuck in a loop and cannot identify them.
In my case 48 tracks added, 0 identified.
Roon keeps on trying to identify. The round wait thingy keeps circling all day (I know, very technical )
How can identify which tracks are causing this issue. I am happy to remove/re-rip, whatever needs to be done, but I do not know the culprits.
I thought that the inspector would maybe identify them as corrupt, but there I have zero corrupt tracks.
While checking these tracks under the inspector, I noticed something to else.
The number of tracks from the overview screen does not match the number of tracks when you click on them to go to the tracks overview.
Overview states 57976 tracks, when you click on tracks it says 53041 tracks.
I only have flac and dsf files. I suspect that the delta is the number of dsf files.
EDIT:
It gets even a bit weirder. The above happens on an iPad Air2. When I am behind my normal PC (remote) Number of tracks are equal.
In Roon terminology, “Identification” is referring to the process by which we send information about your files to our servers, and our servers hopefully return a big lump of rich metadata go with those files.
Your problem could be server or client-side–hard to say. It probably isn’t an indication that anything is wrong with the files.
@mike will be along to help you send us logs, and hopefully they'll paint a better picture.
Many settings are system-wide, but we judged that this one (and other display settings like it) shouldn’t be.
Why? Showing hidden content is a pretty nit-picky/technical feature, and different people prefer different display settings. Less sophisticated members of a household probably shouldn’t be exposed to the more technical settings just because someone using a different remote, or sitting in front of the core machine, chose to operate that way.
Since devices tend to be fairly personal these days, and Roon is designed to provide music to a whole household of people, each of whom may have their own devices and different levels of technical aptitude, we felt that making this a device-level setting instead of a server setting was the best thing to do.
Hey @allineedis – don’t feel too bad. You’re definitely not the first one to be confused about this distinction, and we’ve discussed aligning the two counts.
Anyway, I think you have a support ID from our past discussions so, if you don’t mind, can you send a new set of logs and then send a PM to @vova and myself to let us know when they’ve been uploaded?
What would be helpful is to restart the Core app, confirm that the importing count is getting stuck for a few minutes, and then submit a fresh set of logs. We’ll take a look and see if we can get a sense of whether this is a file causing issues for our importing process, or something else.
I didn’t get any notifications about your post from Oct 13
I’ve examined your logs and I see an error there - waiting for dev feedback. I’ll keep in touch with you.
