Intel NUC NUC8i7BEH 8GB RAM SAMSUNG 250GB SSD (Ethernet direct to Netgear)
ROCK Version 1.7 (build 610) stable
OS Version 1.0 (build 227) stable
DATABASE 96% of 227 GB available
Roon Remote running from HP Elitedesk on Windows 10 (Ethernet direct to Netgear)
NETGEAR GS908E Firmware v1.7.0.2 (Ethernet)
ZYXEL VMG4825-B10A (ISP Provided) - (WiFi) 2.4GHz using CH. 11
Storage
Synology DS416J (91879 tracks) 4.4TB (Ethernet direct to Netgear)
8TB storage at 72% Healthy Configured for SMB1-3
Wired Sonos system using 2.4GHz SonosNet CH 11
Sonos OS: S2
Play:1: Bedroom
Serial Number:
Sonos OS: S2
Version: 12.0.5 (build 58180080)
Hardware Version: 1.20.1.6-1.1
Series ID: A200
IP Address: 192.168.1.142
WM: 0
Play:1: Living Room
Serial Number:
Sonos OS: S2
Series ID: A200
IP Address: 192.168.1.180
WM: 0
Playbar: Living Room 2
Serial Number:
Sonos OS: S2
Hardware Version: 1.9.1.10-1.2
Series ID: A100
IP Address: 192.168.1.223
Audio In:
WM: 0
OTP:
Connect:Amp: Patio
Serial Number:
Sonos OS: S2
Hardware Version: 1.17.3.1-1.1
Series ID: C100
IP Address: 192.168.1.151
WM: 0
OTP: 1.1.1(1-17-3-2.1)
Play:1: Solarium
Serial Number:
Sonos OS: S2
Series ID: A200
IP Address: 192.168.1.57
WM: 0
Sonos Move: Solarium-Move
Serial Number:
Sonos OS: S2
Hardware Version: 1.25.1.8-1.2
Series ID: A100
IP Address: 192.168.1.140
WM: 1
Play:1: Workshop
Serial Number:
Sonos OS: S2
Series ID: A200
IP Address: 192.168.1.86
WM: 0
Sonos Move: Workshop-Move
Serial Number:
Sonos OS: S2
Series ID: A100
IP Address: 192.168.1.188
WM: 1
1-Played tracks from local library end prematurely. Seems random not depending on source quality. History typically shows these tracks at 95% complete but not always. Same tracks will play fine at later time. No crossfading enabled. No DSP enabled.
Problem is not evident on system when not using Roon, i.e. when using Sonos Controller, desktop or ap,
2-Sonos devices frequently do not leave zones when deselected, or will lose audio stream.
