Tracks from my library is not listed when I use filter placed at the right hand top. Unfortunately, the results only shows from music services (Tidal and Qobuz).
When I make a search for a track, roon software should be able to find the ones from my library as well. I hope this issue can be solved asap.
Which screen are you on when you’re searching for a specific track? If you’re on the My Tracks page, it’s worth noting that there are three filters you can apply. The one at the top right filters by album, the one in the middle by album artist, and the one on the left by track title.
For me, when I use the filter or search for an album, it “hides” the local album and only shows the Tidal version if the Tidal version is in my library. If I want the local version to show I have to enable “show hidden tracks and albums” under settings\general:
