I have a problem with roon from time to time stating lost transport between my hard drive and roon. I have a Seagate Backup Plus Hub 8TB connected to a Toshiba sattellite c55 series with a usb cable. I am using a peachtree 24/192 dac it x to connect to my stereo unit. If I use my ipod to connect digital to the dac and then to my stereo I have no problem. My library is quite large 28921 albums. Has anyone run into this problem?
What are the Toshiba laptop specs? Your model number includes some low spec variants that would be wholly inappropriate for a 30,000 album library.
AJ
Processor IntelĀ® CeleronĀ® CPU N280 @ 2:13GHz 2.13 GHz
Installed Ram 8:00 GB (7.89 GB usable)
System type 64-bit operating system, x64-based processor
Yeah, if that is running your Roon core, a Celeron processor is below minimum recommended spec, especially for a large library.
AJ
Thanks for answering me. I will look into buying a new laptop. I had this one since 3/2014.
