Trouble connecting arc from my Verizon cr1000a modem through my orbi 6 satellite system
Can someone understand the response I got when trying to connect to arc.
{“ipv4_connectivity”: {“status”:“NetworkError”,“status_code”:504,“error”:“error: Error: ETIMEDOUT, response code: undefined, body: undefined connected? undefined”},
“external_ip”: {“actual_external_ip”:“173.aaa.bbb.ccc”,“actual_external_ipv6”:“null”,“router_external_ip”:“null”},
“natpmp_autoconfig”: {“server_ip”:“10.0.0.1”,“found_natpmp”:true},
“upnp_autoconfig”: {“status”:“NotFound”}
Any help would be greatly appreciated…
Hi @Bruce_K_McCullough
Could you please answer below questions?
Who is your internet service provider?
Please list the make and model of your modem and router?
Do you have any additional network hardware, like additional routers or managed switches?
Does your network have any VPNs, proxy servers, or enterprise-grade security?
What machine are you using as a Roon Core, and how is it connected to the internet?
Kind regards,
Maarten.
Who is your internet service provider? Verizon
Please list the make and model of your modem and router? Verizon CR1000A
Do you have any additional network hardware, like additional routers or managed switches? Downstream of Verizon Modem/Router I have a Netgear Orbi Router RBR850 with (3) RBS850 Satellites
Does your network have any VPNs, proxy servers, or enterprise-grade security? Not that I know of
What machine are you using as a Roon Core, and how is it connected to the internet? I have a nucleus that is connected to internet using an ethernet connection.
any help with my configuration? this is what the message stated:{
“upnp_autoconfig”: {“server_ip”:“10.0.0.1”,“found_upnp”:true,“error”:“<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/\” s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/\“><s:Body><s:Fault>s:ClientUPnPError<UPnPError xmlns="urn:schemas-upnp-org:control-1-0">501ActionFailed</s:Fault></s:Body></s:Envelope>”}
Hi Bruce,
Not official support just a fellow user
The diagnostics you’ve provided suggest that UPnP is not properly configured on your router.
Please first try the following steps:
  • Try to enable UPnP/NATPMP in the web administration interface for the router directly upstream from your Core
  • Try to manually open the port in your router’s port forwarding configuration
  • Make sure the IP/Port matches the Port listed in Roon → Settings → ARC
  • Check for any VPNs or Firewalls that might be interfering
  • Check if your modem is in Bridge mode
