Who is your internet service provider ?
Please list the make and model of your modem and router ?
Do you have any additional network hardware , like additional routers or managed switches?
Does your network have any VPNs, proxy servers, or enterprise-grade security ?
Description of Issue -
What is the exact port forwarding error message you see in the Roon Settings → ARC tab?
Hi, I’m having trouble connecting ARC through a Zyxel LTE7460-M608. I get this error message:
“external_ip”: {“actual_external_ip”:“217.ddd.nnn.ooo”,“router_external_ip”:“null”},
“upnp_autoconfig”: {“server_ip”:“192.168.X.X”,“found_upnp”:true,“error”:“doaction request return statuscode: UnknownError”}
Did you try the steps mentioned in this article:
Overview Roon ARC is designed to connect to your Roon Core from outside your home. This allows you to access your Roon Core on the go so you can play your files and streaming content, in addition to updating your library, playlists, favorites, and...
If that doesn’t help/work please answer the following questions of the form so support or other community members can assist you.
Hi @Bengt_Sederlin ,
Welcome to the forum.
I think a manual port forwarding rule will solve your issue.
I couldn’t found a youtube video of your router model, but found a manual (here ).
First in the Roon App go to Settings → Roon Arc and write down the ip address and port number.
Then see page 67 in the manual.
Under private ip enter the ip address you wrote down.
Under private and public port enter the port number you wrote down.
Under protocol select TCP**
Then click Apply.
Hope it helps.
Maarten.
system
(system)
Closed
December 16, 2022, 6:22am
#5
