@support You may recall that last night I converted my NUC (a conforming 6th-gen i3) to ROCK. I’ve listened to it for much of the day. Tonight, after a couple of hours out, I tried to play some music but it wouldn’t play. Remote looked fine, it found the server, I could select an album or track, the play button turned into a pause button, but the time didn’t progress–stuck on 0:00:00.
So I connected via the web interface and restarted the Roon software. It restarted fine but it didn’t fix the problem. So I tried to restart the device from the web interface–but that didn’t work. Timed out. I got a message saying I needed to do it manually.
So I pushed the button and the blue light went out. I pushed it again and it came back on. But now the Remote can’t find it and I can’t connect via the web interface. I’m assuming the IP address hasn’t changed.
What next?
