I cannot get any of the BBC stations to run. I can access all my other stations and music but none of the many BBC ones. All that happens is it says “Started live radio” but I just get a blue light moving from side to side in the bar below and eventually the message “playback interrupted because a track failed to load” appears. As I mainly listen to BBC stations this very frustrating!
The BBC radio streams move around so you could try deleting one and re-installing it. I’ve got Radio 2 and 4 playing fine in Birmingham (NUC with ROCK).
Thanks for all your responses. Robert, I did try rebooting my Nucleus when the issue first occurred but with no success. However, I’ve just tried it again after shutting down everything and this time it has worked, so problem solved.
