Connected via ethernet to home network.
USB: Sony TA-ZH1ES
Network: Various Airplay devices
When I start the Roon player on any device (PC, Phone, Table, etc.), it shows the animated Roon loading icon, but never finishes loading. I can access the Nucleus+ via the browser using the IP address. I’ve rebooted the Nucleus+, but the Roon player is still not able to load any albums. However, I can access the settings and they look correct. That said, it showed a warning that it was not able to log into Qobuz. When I try to reset the password, it does not load the UI for it. So it seems the settings UI is only partially working.
I noticed the problem in the afternoon, but I suspect it happened because of a power outage we had in the morning.
Any suggestions to get the Nucleus+ running again?
Okay, looks like the patient has recovered after this procedure:
Unplug everything
Wait 15 minutes
Plug everything back in
Power on
Wait 15 minutes
Really strange. My best guess is that the power outage caused the network interface to go into a funky state that was only resolved after completely draining the Nucleus+ of any residual power.
