Hello, i am trying out Roon on the 90 day trial as part of the Kef promotion. i have set up roon on my PC and it’s works fine. i then downloaded the app on my android to play the music but i am told that my membership only allows 1 device to manage my library.
However i am not expecting the app to manage my library with the app but simply to play/stream the tracks. is this not possible with the trial? I assumed it was part of the full trial experience.
Hi, @batDroid, thanks for the report, could you please post a screenshot of what your are seeing on your Anroid?
Basically your memberships allows you to own one Core (your PC) to manage your Library and you can connect various Remote device to it, to control the Core. You can learn more here and here.
if i click unathorize on app, the laptop then displays the same message on the screenshot. However i have just noticed that this laptop displays this message “oops, i meant to run as a remote control” but this is not present on the app.
ideally i want the laptop to manage library and phone as remote.
Hey @batDroid – you’re only going to see that message when you’ve configured a Roon Core on more than one device.
Android devices aren’t able to run the Roon Core, so I’m guessing you’re running Roon somewhere else too? Did you install Roon anywhere else that might be trying to run the Core?
Just want to check in here because I saw your latest message, seems that you were running Roon in 2 locations from what I understand? Has the “Authorizations” window disappeared now that you have removed the other Core and the system is working properly? Please let me know when possible!
