Mac mini (Mid 2011)
2.3GHz core i5
8GB RAM
Roon 1.8 build 923
BT router
Cambridge Audio DAC Magic
8000
Music will play for a minute or two after pressing play and then stop.
Logs show loss of stream to DAC
04/07 16:12:08 Trace: [Cambridge Audio DAC100 USB 1] [raatclient] GOT [12] {"status":"Dropout","samples":34670}
04/07 16:12:08 Trace: [Cambridge Audio DAC100 USB 1] [raatclient] GOT [12] {"status":"Dropout","samples":45056}
04/07 16:12:08 Trace: [Cambridge Audio DAC100 USB 1] [raatclient] GOT [12] {"status":"Dropout","samples":49152}
04/07 16:12:08 Warn: [cambridge dac] [zoneplayer/raat] long rtt sync Cambridge Audio DAC100 USB 1: realtime=147247434008 rtt=315500us offset=-24593565us delta=-316192us drift=-323808us in 124.524s (-2600.374ppm, -9361.345ms/hr)
04/07 16:12:08 Trace: [Cambridge Audio DAC100 USB 1] [raatclient] GOT [12] {"status":"Dropout","samples":40960}
04/07 16:12:08 Warn: [cambridge dac] [zoneplayer/raat] Too many dropouts (>3s dropped out in the last 30s). Killing stream
04/07 16:12:08 Trace: [cambridge dac] [zoneplayer/raat] too many dropouts. stopping stream
04/07 16:12:08 Info: [audio/env] [zoneplayer -> stream] All streams were disposed
04/07 16:12:08 Warn: [zone System Output + cambridge dac] Track Stopped Due to Slow Media
04/07 16:12:08 Trace: [cambridge dac] [zoneplayer/raat] Endpoint Cambridge Audio DAC100 USB 1 State Changed: Playing => Prepared
04/07 16:12:08 Trace: [Cambridge Audio DAC100 USB 1] [raatclient] SENT [28]{"request":"end_stream"}
04/07 16:12:08 Debug: [raat/tcpaudiosource] disconnecting
04/07 16:12:08 Trace: [Cambridge Audio DAC100 USB 1] [raatclient] GOT [12] {"status":"Ended"}
04/07 16:12:08 Info: [audio/env] [zoneplayer -> stream -> endpoint] All streams were disposed
04/07 16:12:08 Trace: [Cambridge Audio DAC100 USB 1] [raatclient] GOT [28] {"status":"Success"}
However running DAC directly via Qobuz works fine.
This issue seems to have started after latest Roon update.
