USB 2.0 or USB 3.0 for Chord Mojo on my Raspberry Pi 4?
Hi everybody,
just installed RoPieeeXL on my new Raspberry Pi 4 that I will use connected via USB to my Chord Mojo and I will be in wi-fi.
My question is: should be better to connect Mojo to the USB 2.0 or to the 3.0 port?
I ask this because in the past somebody stated that with audio is always better the 2.0.
What do you think and what do you use?
I use 3.0 with my Meridian Prime, but I couldn’t tell any difference and both seemed to work OK.
