USB Connection loss from Pi4 with 7'display to IFI Zen DAC V2 after some minutes
4c24c1d05a616726
Is there something in the LOG in relation to USB or Voltage?
Thank you for help!
Do you have more than one Roon server? If so, go into Roon - Settings - Extensions and remove the extension on the server you don’t want to connect to.
There is. I see regular disconnects from your USB DAC. No errors though, just a regular disconnect. Maybe you can try a different cable?
One more observation: I see that you have more than 1 RoPieee unit’s (awesome!). Make sure they have different device names. The logs suggest (I’m not entirely sure) that you have at least 2 units that both have the device name set to the default ‘ropieee’. Anyways, not a huge thing and certainly not related to the USB disconnect.
Thank you. A shorter cable works. And I renamed the second RoPieee.
