@support I am running Rock 1.4 build 294 on a 7th gen nuc i3. My dac is a card onboard my Modwright KWI200.
If I connect my USBridge (DietPi) to the dac it shows in Audio Settings Network Devices as a HiFace. I can enable it and all is well. If I direct connect the Rock via USB to the Dac nothing shows under Settings Audio Connect to Rock apart from HDMI and Analogue out devices.
Its not a big deal as I don’t intend direct connecting to Rock but was curious to see if there were differences.
Hi @Tony_Reimann ----- Thank you for sharing this observation you’ve made with us, the feedback is always appreciated.
If the KWI200 is working on RPi (w/DietPi) it should be able to work with ROCK as well. Based on your post it doesn’t sound like you intend to use the device mounted to the your NUC but if you would like to troubleshoot this please let us know.
You are right, I don’t see me playing direct out of Rock USB but who knows in the future. Happy to troubleshoot. I believe Dan Wight stopped doing the dac cards for the KWI as there weren’t drivers from M2Tech foe later versions of macos but I have never had a problem with linux until now.
@Eric no response from you. One idea I have is the hiface driver may be missing from rock. It is included in dietpi and that works for me. I believe Modwright used the hiface dac board from m2tech.
Hi @Tony_Reimann ---- Apologies for the slow response here.
Moving forward, I mentioned your latest post in a meeting with our tech team today and one of our technicians remembered reading that devices making use of the M2Tech V1 hiFace need to be on when the host machine is booting up. Can you verify if the KWI200 was powered up before ROCK when you noticed that application couldn’t pick it up?
Thanks for touching base and sharing your feedback with me @Tony_Reimann, appreciated!
Moving forward, I have went ahead and enabled diagnostics on your account so we can take a closer look into this behavior when the device is mounted to ROCK. What this action will so is the next time the application is active on your NUC a diagnostics report containing a set of Roon logs will automatically be generated/uploaded to our servers. I will confirm when the report has been received so you know we have and then I will be passing over to our techs for further analysis.
-Eric
UPDATE: Confirming the report has been received. I think that may have been some kind of record
Thanks @Tony_Reimann, I went ahead and re-enabled diagnostics this morning. It looks like the report has been received.
I am going to be preparing your ticket for our tech to review and once it has been updated/passed back to me I will be sure to share our techs thoughts/findings with you in a timely manor.
Hi @Tony_Reimann ---- Thank you for touching base with me, hope all has been well.
I just checked in with our tech team and the mentioned fix is still undergoing testing in our QA lab. Once the team provides me an update on where they stand in their investigation/testing, I will be sure to touch base *asap. Your understanding is appreciated!
