Flere
1
I would like to be able to set the volume range for a USB connection.
So that I can use the full range of the UI slider and +/- buttons.
Problem description
My USB connected DAC is already very load at roon volume 50.
It would be nice if I could scale the slider / ±buttons.
RBM
(René)
2
You can: in Device Settings, choose Volume Limits.
When you limit the Safety Limits to 50, the entire slider is used for the 0-50 range.
Flere
4
Tested it. This is indeed what I was looking for!
I am very happy with my Nucleus connected via USB to the BeoLab 50.
