Using 3 Mytek DACs for multichannel
I have been running 3 Mytek Brooklyns via a USB hub which MacOS can aggregate into a “virtual” 6 channel DAC. JRMC sees each individual DAC as well as the aggregate device which permits 5.1 playback. Roon sees only the three individual DACs.
Update: It does “see” the Aggregate Device" of the three DACs but it will not permit choosing anything but 2.0. Still, it does not play anything but displays “Transport: Device In Use.”
If I choose any of the three individual DACs, the stereo output goes to (1) front L/R, (2) center/sub or (3) rear L/R speakers, depending on the choice…
How can I get all three at the same time?
@support tagging support here for you but this might ultimately belong under feature requests as doing multichannel over 3 DAC’s IMHO is far away from the general punter setup.
Perhaps but support for an aggregate device of core audio is not so strange.
Hey @mitr – just to let you know, we’re aware of Mytek’s capability here but it’s not we’ve tested or tried since we only have one Brooklyn in house.
We can take a look at this, hopefully we can figure something out without needing two more Brooklyns :innocent:
Technically, one could do this with any 3 DACs since the critical issue is recognizing the aggregate device as consisting of 3 physical USB devices. The only thing that the Myteks bring to the dance is their ability to synch their WCLKs. You could test this with 3 DragonFly DACs or, even, a mixed trio.
OK. Here we go again. @Mytek_Official I am working now with a WinPC.
I can play each of the 3 Myteks individually to the appropriate amp/speaker channels. Then I added procedural filter to each so that the stereo L/R output is the Front L/R for Mytek1, Center/Surround for Mytek2 and Rear L/R for Mytek3. Each was then given a different Master Clock priority according to how I named them.
However, when I link the three into one zone and play them together, I get the message:
How can I play them together as a single zone?
I have different dacs and even the aggregated device isn’t seen. My guess is Roon staff don’t give a ■■■■ about this issue. :frowning:
