I am using HQP 4 with two different devices as follows:
Device #1: Raspberry Pi/Ropiee/Hifiberry with NAA Backend. Note: I use this set-up to listen to Spotify via HQPlayer.
Device #2: Roon and T+A DSD 8 DAC (ASIO backend) connected via USB. Note: I use this set-up to listen to Qobuz and my own music library via HQPlayer.
Whenever I want to change music sources (Spotify or Roon/Qobuz), I must access the settings in HQP and manually make changes. This process can become tedious.
Question:
Is there any way in HQP to save each setting to facilitate switching between different devices/sources in HQP?
I also have HQP 3 installed in my computer. I presume that I could use HQP3 with one source and HQP 4 with the other source. Any thoughts on that possibility?
I have two devices that I use with HQP v4. To listen to each device, I have to go into settings in HQP and manually change several parameters.
Is there a way to “save” the settings for each device (this could be similar to creating a profile for that device) to facilitate switching between devices?
If that is not possible, could use HQP3 with one device and HQP 4 with the other device?
