Using iPad causes audio issues
Hi,
I have tried a lot of things but I am at a loss. I have Chord Poly and have run Roon on a Mac Mini late 2012 and now on my gaming laptop. Have tried different routers and network configuration but I keep getting “Audio File is Loading Slowly” stuttering and sound issues. It appears to happen especially when I use the iPad to browse through my catalog or through the Tidal content. There are 33000 tracks in the catalogs and some 2500 albums. Most of which come from Tidal +/- 1500.
Internet speed is 400mbps and when i play via DLNA via the ipad from Tidal using Mconnect all is well. So it really appears to be a Roon issue.
I have no DSP, no upsampling, not even master tracks required to cause the issues.
Hopefuly there is something that can be done because I really like Roon but being able to actually listen to music is not working.
Regards,
Marcel
Hi @Marcel_Schot,
So we can better assist you, please describe your network configuration/topology, including any networking hardware currently in use, so we can have a clear understanding of how your devices are communicating.
If you play to System Output of the Core machine does the same behavior occur here?
Hi Dylan,
I have been very busy and have not used Roon at all since my question. Yesterday I discoverd an update for the Poly I am using and that appears to be a lot better.
After I have some more experience with the new update I will send an update to this topic.
I have read comments from other people that the update has improved their similar issues.
