Affected Product
Roon
Roon Issue Category
Installation or Setup
I would like to know if with Roon is it possible to use the Stream Box S2 Ultra streamer as Core+endpoint, therefore not using the PC as the core but the stream itself.
If yes, how can I do it? Is it necessary to download some software patches? Since the Pro-Ject streamer is a Roon ready device and I have an unlimited Roon license (Lifetime membership), should there be a possibility to make it also work as a Roon core (not just endpoint)? Awaiting your response, I cordially greet you. Thank you.
Roon Core Platform
Windows
Roon Core Specifications
Asus pc, i7, ( MB RAM
Pro-ject Ultra S2 streamer
Home Network Details
Ethernet
