Hey. Is it possible to wireless stream roon to a wireless receiver that converts to ethernet?
I am moving soon to a place with no wall ethernet ports, and I’m getting worried I won’t be able to set up roon in two rooms. Does anyone have a solution or suggestion?
Sure. You can operate via wifi, Ethernet over power, or Ethernet over coax (MoCA). Sounds like you want to utilize a bridge. Hard wiring is always best, but the alternative methods will work. Data from the core can be transmitted to the end point, and the DAC, or combo DAC endpoint player.
