Volume control - extreme caution required
New to Roon. After installing core on my PC it discovered 2 of my networked AV systems and I can listen using AirPlay so until I add Roon end points I figured I could at least get familiar with navigation, etc. Unfortunately I just blew out a $1000 sub-woofer when I switched input to Roon because the “fixed volume” setting overloaded the system. I have a Crestron control system and will have this set so that volume is turned way down before switching to Roon but would have liked it better if Roon line output would have been less or at least a clear warning about this danger had been evident.
