Roon Core on Synology NAS (great stuff)
All Devices via CAT6 Switch 100M/1G
NAD M10V2 via Airplay2
11,000
I use a NAD M10V2 and other Airplay2 devices like Onkyo R-N855,
The NAD M10 ist in Airplay2 mode to enable grouping with other Airplay2 devices.
If i change the volume of the NAD at the device, it is not changed/synced in Roon Interface (Ipad, PC).
If i change the Volume of the NAD at the Roon Interface, it does change the NAD’s volume.
If i change the NAD’s Volme at the device, it will change the volume of any direct Airplay2 connection via Ipad.
So, only if i Use M10 in Airplay2 mode and change the volume at the device, Roon does not recognise it.
Any Idea what to do?
Thank you !
best, Robert
