Volume control not working properly
nuc i5 gen 11 16 g ram
Dutch and Dutch 8c
Controlled via iPad
TP link Archer 2800 modem/router
Dutch and Dutch 8c connected to Lan via power lines and Ethernet cable
About 40.ooo tracks
When in the Roon app on the iPad and wanting to change volume, touching the volume slider knocks the 8c off and I get the notification that there’s no attached playback device
All worked until about four days ago
Please resolve
Thank you
What troubleshooting have you done so far?
Hi Hickman
I have turned off/on everything in the replay chain
Did that include the networking equipment?
Yes everything was cycled
Hi
Has anyone else experianced this problem?
core 2.0 (build 1234)
This tablet2.0 (build1219
I hope I have given the right info
Thanks Menzies
instantaneous
The phyisical volume control on the ipad has the same effect
the 8c gets knocked off then comes back on again after a few seconds.
Completly ruins the listening experiance
Good day Lewis
The 8c is on 2.2.33
Thanks again for your time
Hi @Gerald_Gosnell,
Thank you for your patience and please excuse the long delay. Are you still experiencing volume control issues on this endpoint?
