Can anyone help me out, I have just received my Dion Audio Loco AMP.
I have several Pi’s running Dietpi as Roon endpoints in my house. All are configured with volume control set to use device controls. Now with my Loco this is not working and I am now using DSP volume control.
Within Dietpi there is no preset for the Loco. It automagically was recognised by Roon and didn’t need to select the audio device in the Dietpi Config menu.
Can I use the HifiBerry AMP profile or is there an other way?
As far as I can see, the correct overlay is present in DietPi. It could be that the Loco supports autodetect and the correct overlay is loaded automatically – otherwise you may have to add ‘dtoverlay=dionaudio-loco’ to /boot/config.txt.
