Hello there
I was wondering if it would be possible to use the control media of my MacBook Pro 2018 for the sound. So far, I deactivated iTunes Helper so i can do previous/play/pause/next tracks. Great!
However, I can’t control volume.
I tried the shortcut cmd+up but i can’t change it.
- Do you plan to let users edit/change shortcuts?
- If it is not possible today, are you planning to let users control volume with multimedia keys from Mac?
Thanks in advance for your help.
