Hi,
i am new to Roon and I have issue with volume control. My setup is the following
PC W10-64bits (core) =>Ethernet=> switch=>Ethernet=>Digione Signature DietPi (Roon bridge)=>Spdif=> Audio GD 19 DAC=> RCA=> Heed Elixir amp => Audio Physic speakers
It is impossible to control Digione volume within the app. if i choose Peripheric volume in the digione setting it has the same effect as fixed volume.Volume limit values are all set to zero without possibility to be changes.
Is there a solution to achieve volume control within the app?
BR
