Hi,
my problem is that the volume is not responding to the control bar on any roon remote. I can move the slider left and right but the volume stays the same. only when I click the mute button it mutes, but then I can’t unmute via roon.
I then have to turn up the volume directly on the Stream Box’s web interface. This might be a compatibility issue between Pro-Ject and roon…
Worth noting, that it had worked previously a few years back (hadn’t used the roon + streamer combo since).
All Firmware is up to date.
thank you for your response. Yes, the issue remains.
Well my problem is that I DON’T want to have fixed volume, but it acts like it’s fixed regardless of what setting I chose.
Switching back and forth between the two settings doesn’t do anything either.
thank you for your reply, Jack.
I also suspect that the problem is with the Stream Box. I have changed every setting and it is still not working though:
