Hi Dylan, again.
Now i´m using a USB cable from the Zenmini to the Devialet and the volume control, in roon, appears different than the usual, doesn´t correspond to the amp volume values.
I tried to configure without success.
Is it suppose to be luke that?
Hi @Rogerio_Boldt,
Can you share a screenshot of Device Setup for the Devialet as well as a screenshot of what you’re seeing for the volume control?
Thanks Dylan,
I know already, with others Devialet users, that´s not possible in this configuration (USB) to use the Roon volume control like we use in Devialet/AIR or Roon/RAAT configuration.
So, i´m clarified, sorry for this and thanks so much, again.
Cheers,
Rogério
