Volume Level at start for each audio device
Hallo
How can i set different volume level for each device.
Some devices use higher or lower level. When starting a device with the roon app, the used device use the volume level from the last device. Sometimes this is very loud.
For this it would be great to set a start volume level for each device when this ist started with the roon app.
I did not find an special answer to this and no settings in the device setup.
Best regards.
Using NAD M33, M10v2, Yamaha MusiCast 50
Never seen this happen. Each device is unique and has its own volume level. Swapping playback from one device to another I do not experience this and they use the devices volume setting.
Are you using groups or have the iOS Lock Screen control active as this is known for setting volume wrong but Roon seem to have done nothing about it. I have this off as it turned my device to full when activating it.
