I read other similar thread about it but still cannot find a solution.
I don’t have an MQA dac (I have a Mojo) and I have the latest Roon (my endpoint is an iPhone 8 Plus).
My Roon library is composed by:
Tidal
Tidal MQA
Flac with RG
MP3 with RG and sometimes with Mp3Gain tags
I really never reach out to achive a volume normalization on my library, I Always need to adjust the volume… There is an guide I can follow to try to solve?
Take a close look at the GIF: You have to click on the volume slider and then on the cog wheels.
Sorry, perhaps I’m just slow but I DID “look at the GIF.” I have no “volume slider.” My “Volume Control” setting is “Device Volume.” Is that why I have no slider?
I think so, but it depends on how/where you listen to music and what albums you have. There are some with high dynamic range between tracks which could sound more quiet than expected. That’s correct for Album listening in most cases, but it could be annoying in loud environments. Then always track wise leveling could be your choice.
