I am using volume levelling a lot more recently as I use Roons radio a lot and it helps keep things as a level I don’t have to alter the volume. I have it set on auto so when Roons playing an album it chooses a constant level for then album and for tracks from radio it adjust each one track. However it fails and requires manual intervention for compilation albums as they don’t sound right using album mode it needs track mode. Then you have to remember to put it back to auto.
So this made me think it would be handy to have an option to set the volume levelling setting per album if needed. I know others have requested per album DSP options so I guess this also falls under that
