When I turn off/on speaker the volume limits do not work and the volume starts at 100 while I limit them at 30
So when I turning on the speaker the volume is very loud.
Unfortunately it does not affect what the speaker itself is doing at power on which in this case is resetting the volume. Volume limits only affects volume interaction iwhilst your in Roon. Roon will start with the system level. So if the system or other software has set it higher it will start in Roon at that volume regardless if it’s above Roons limits the limits stop you raising it above that level in Roon accidentally. Had this issue as well on devices and that’s what support said it’s annoying.
